John B wont start
Roger Rachow
08-01-2002 15:26:05
I have a 1952 John D. B. It usually starts very easily, recently it started then stopped and wont start again. Is getting gas. Where are the points and condenser on this tractor? Also should one replace the coil? I took the lead from the coil and hit the starter but no spark. Any ideas?
Clooney
08-01-2002 17:18:39
 Re: John B wont start in reply to Roger Rachow, 08-01-2002 15:26:05
Roger, make sure you have power to the coil, if so see if you have power to the distributor side of the coil with the points open, & the distributor side power goes away with the points closed. ~If the distributor side stays powered all the time your points aren't closing, are oxidized or burnt or the wire between the coil & distributor is open.
~If you don't have power on the distributor side of the coil, remove the wire going to the distributor & see if you do then, if you do, you have a short to ground in the points, condenser, internal wire, or wire between the coil & distributor or the points aren't opening. ~If you still don't have power on the distributor side of the coil the coil is open & defective
~If the power on the distributor side of the coil is ok per above, suspect a bad rotor, cracked cap, open in the condenser, bad plug wires or maybe a defective coil.
~The points & condenser are in the distributor, [can't tell you where in the distributor without knowing the distributor brand & type]....
