JD pistons
Terry
08-01-2002 13:19:12
Looking for a set of 0.060 or 0.070 over pistons for a JD A. Thank's. Terry
Seamo
08-01-2002 14:23:13
 Re: JD pistons in reply to Terry, 08-01-2002 13:19:12
Styled or unstyled "A" They come in std. +.045,+.090,+.125 oversize Plus some tractor pulling size 5.750,5.875.I use Hinrich's Pistons Area code 815--778-1900 central time. Very good Quality and reasonable prices. Earl
Steve II JD A 44
08-01-2002 15:26:58
 Re: Re: JD pistons in reply to Seamo, 08-01-2002 14:23:13
HI are those piston, do they give power than JD piston? what are they make of.
Jack
08-01-2002 14:41:17
Hey Earl,did I tell you about getting my DLTX51 working properly on my 53 G?It had a rusted up hole that did not even appear to be ever be a hole.Now I just need to come up with about two to three more ponies.My friend had about two more ponies than me on the dyno and it showed up on the track Saturday.He out powered me several feet.Later,Jack(TN).
Steve II JD A 44
08-01-2002 19:21:04
 Re: Re: Re: JD pistons in reply to Jack, 08-01-2002 14:41:17
is not there a cam from later tractor to put in older tractor that may help boot the power like putting a cam out of a jd 60 in jd A?
G Taylor
08-03-2002 08:21:45
 Re: Re: Re: Re: JD pistons in reply to Steve II JD A 44, 08-01-2002 19:21:04
The cam duration and lift is identical on 47 and later A's,60's,and 620/630's.
Steve II JD A 44
08-03-2002 11:53:15
 Re: Re: Re: Re: Re: JD pistons in reply to G Taylor, 08-03-2002 08:21:45
I was told that 620 and 630 are too far different. and 60 will work. I not really so sure what my choose will be.
G Taylor
08-05-2002 00:14:15
 Re: Re: Re: Re: Re: Re: JD pistons in reply to Steve II JD A 44, 08-03-2002 11:53:15
I have it in writing from the Two Cylinder Club's copy of JD specs, JD parts manuals and from J.R. Hobbs copy of JD specs that the late A, 60 and 620/630 use the same lift and duration. Intake 10 aTDC/40 aBDC and exhaust 45 bBDC/5a TDC.Valve lift is .4536" All the 60's had larger valves than the gas or LP 620/630 as well.
Seamo
08-01-2002 19:14:31
Jack I always like to hear how everything works out. I cant figure out whats wrong with my E-mail right now.But I would like to here about your "G" and maybe we can find little more power to beat him.(ha! ha!) Do you have tractors just alike?? Earl
