JD 60 Hydraulics
Scott
08-01-2002 11:16:47
I have never used the hyraulics on my 60. I have an aftermarket 3 pt. hitch and the power trol feature. There are two ports on the back near the PTO which I know are the hookups. There is a small lever which you can turn 180 degrees. I assume this will divert the oil from the 3 pt. hitch to the remote and that you use the same control lever as the hitch. Are both ports pressurized? Any help or advice would be appreciated.
Tony
08-01-2002 15:34:02
 Re: JD 60 Hydraulics in reply to Scott, 08-01-2002 11:16:47
Call me at 563/285-5945. I have a copy of the hydraulics manual and can walk you through it. I'll fax a copy of it to you if you want.
