3 pt hitch for 1940A
Terry
08-01-2002 11:14:50
I came across some 3 point parts that I believe are meant for early JD A's. The Upper arms that attach fine to the rock shaft, but I am not sure how the lower arms attach to the rear end/drawbar bracket. The Upper arm casting numbers are P876A and P877A and the lift bars are P814A. If anyone has any information or pictures I would greatly appreciate it
Jerry S
08-01-2002 14:34:48
 Re: 3 pt hitch for 1940A in reply to Terry, 08-01-2002 11:14:50
The deere made hitches have the two point arms hooking to a bracket that bolts onto the drawbar assembly brackets but the more square kind rather than the triangular kind the early tractors had. It basically is an angle iron setup with a pin welded to it the eye goes onto. There is a picture out in the photo section I believe that shows a hitch but I am not sure you will want one on your tractor since the lift arms are either all up or all down. Power trol lifts let you be up only as far as you want. You may need to fab something to make the drawbar assembly connect to the two point arms. Even after you do that, you will have to have the third point to make it work and that may be the more difficult one to get made.
