John Deere 430
redrev
08-01-2002 08:30:17
Can anyone tell me where to look for the SR.# on a 430 that is missing the SR. number plate? It must be stamped or cast on the tractor somewhere. Thanks. George
redrev
08-02-2002 10:15:48
 Re: John Deere 430 in reply to redrev, 08-01-2002 08:30:17
Thanks...appreciate the help!
Mr. Thinker
08-02-2002 10:08:17
If the serial number plate is gone, you're just SOL--almost. If the engine block has never been replaced, there is a number stamped there which can be traced to the serial number. You'll have to contact your friendly local JD dealer, and ask to speak to his Territory Manager the next time he's around. If you can find the engine number (located on the RH corner of the block, on the boss where the front end support bolts on) the serial number can be traced, and you can get a new serial number plate. It won't be like the original, but better than nothing. You'll also need to know the chassis type, etc.
