Hydraulic seals for MT levers
Sean Coyle
07-31-2002 19:53:38
Can anyone point me to a place that would carry the seals for the lift levers on an MT? Anywhere in western NY or online would be great! Thanks in advance!
4 bar ranch
01-08-2005 23:32:50
 Re: Hydraulic seals for MT levers in reply to Sean Coyle , 07-31-2002 19:53:38
Hey pal,
All you have to do is get the measurements for the seal and go to any reputable parts store and they should be able to guide you to where you need to go if they cant help you there. Question for you. I recently bought a mt and am having trouble figuring out the controls and fluids for the trhee point system. There are two controls int the center and the one to the right raises and lowers, what does the one on the left do?
Chris
Richard
07-31-2002 21:19:50
I bought mine at my local Deere dealer. I can't recall how much I paid as it was a couple of years ago, but what I rememnber was the long needle nose I had to use to reach in the deep reseviour cavity to unpin the lever shaft which you'll have to slide out to replace those seals. Deere should also supply you with a new reseviour gasket as this has to be unbolted also.
