AXLES HOW TO PROTECT WITHOUT PAINT
C. BARBER
12-18-2003 14:36:34
I just spent several weeks removing the rear wheel from my 47 B tractor. After painting it and putting it back on I would like to protect the axle from rust, but would still like to be able to move the wheel in and out for plowing. If I paint the axle I will have to remove the paint every time I want to move the wheel. Does anyone have any suggestions on how to protect the axle?
Scott Old44B
12-19-2003 18:24:05
 Re: AXLES HOW TO PROTECT WITHOUT PAINT in reply to C. BARBER, 12-18-2003 14:36:34
I painted my axles with slip-plate graphite paint, doesn't attract dirt like oils & grease, good dark greyish black color, and when I had to move my wheels in (forgot to measure the trailer), the wheel hubs slide real easily.
DAOS bob
12-20-2003 18:31:10
 Re: Re: AXLES HOW TO PROTECT WITHOUT PAINT in reply to Scott Old44B, 12-19-2003 18:24:05
Clean the axles good, and just spray a light coat of John Deere BLITZ black from a spray can. A nice original looking satin black color axles.They will not rust or collect dust like grease.
Randy
12-19-2003 07:06:27
Just got through restoring a G and after I painted axles, later put on anti-seize. I've never had any problem with wheels after doing this.
Mike M
12-19-2003 06:30:43
Back when my uncles used these tractors they would smear grease on the axles then wrap with rags then a layer of tape, electrical or the white
filliment tape for packages. When I inherited these and restored them I cut that stuff off with a razor knife and the axles looked like brand new.
jd-tractor
12-18-2003 19:16:08
Duro -Lube or fluid film works the best.
520-LP
12-18-2003 18:59:24
Kroil makes some stuff called weatherproof to treat new metal to keep it from rusting for a year works good
RayP(MI)
12-18-2003 17:58:20
Keep 'em clean and wirebrushed, and a little oil or grease from time to time should work fine. No magic here - where you get in trouble is where previous owner neglected to take care of this periodically! Doesn't hurt to move wheels from time to time, so rust doesn't form and freeze the wheels fast. That way you can clean and oil entire surface of axle. Be sure to keep wheel clamping collets tight, and don't forget to retighten from time to time. A little grease on these, and the bolts will help out greatly too.
RayP(MI)
12-18-2003 17:44:30
Keep 'em clean and wirebrushed, and a little oil or grease from time to time should work fine. No magic here - where you get in trouble is where previous owner neglected to take care of this periodically! Doesn't hurt to move wheels from time to time, so rust doesn't form and freeze the wheels fast. That way you can clean and oil entire surface of axle. Be sure to keep wheel clamping collats tight, and don't forget to retighten from time to time. A little grease on these, and the bolts will help out greatly too.
Ron
12-18-2003 17:09:43
Has anyone used LindSeed Oil on the axles..??
Old fire-arms were not blued, they were rubbed with Lindseed oil..Seems that must have worked..!!
I have always seen the outer-most part of the axles wrapped with Oiled Burlap...
We just kept a film of oil on ours, and they are fine, yet...
Tom in Mo.
12-18-2003 16:20:36
I just use a little motor oil rubbed on the exposed steel with my finger. It will last a long time if the tractor just sits; and if you like to use it once in a while, it's easy to smear a little on before putting it away. The factory didn't blue 'em.
Bob Collins
12-18-2003 14:45:35
A couple years ago someone on here suggested gun blue on axles. I tried it on one and am very pleased with the results. It works better if it is quite warm (my shop is not) and one should have the axle very clean and rust free. Sorry I can't credit whoever had the idea first. Bob
Wayne in Tn.
12-18-2003 15:58:28
 Re: Re: AXLES HOW TO PROTECT WITHOUT PAINT in reply to Bob Collins, 12-18-2003 14:45:35
That sounds like a good idea! The gun blue. I remember blueing a shotgun years ago and it worked good. I think you can buy it at most discout stores like Walmart. Seems as if I had to put 2 or 3 applications. Other than that, just use a thin film of grease.
ff316
12-18-2003 19:42:57
 Re: Re: Re: AXLES HOW TO PROTECT WITHOUT PAINT in reply to Wayne in Tn., 12-18-2003 15:58:28
How about stove polish, or would that blacken them too much?
