2510 starter
7700
07-31-2002 18:47:36
My 2510 starter does not engage sometimes....when you push the start button it just spins the starter. Then after the second or third try it will engage. It has been this way for years now...should I assume it is the solenoid? Can the solenoid be purchased without the entire starter?
Pricy item at the parts counter?
Ray
07-31-2002 19:19:02
 Re: 2510 starter in reply to 7700, 07-31-2002 18:47:36
Best thing to do is take it someplace for repair.
It might not be the solenoid,could be the starter
drive.It also could have damaged the flywheel.
We have a couple starter repair shops in the
area that are a lot cheaper than JD dealers.
Low voltage can also cause the starter not to
ingage like it should.Make sure the battery cables
are clean,and the ground cables are making a good connection.
