How tight?
JD JACK
07-31-2002 17:04:28
On late model B, how tight is the castle nut on the first reduction gear shaft? And that shouldn't be back off, correct?
And how tight should the flywheel nuts be?
Thnaks JD JACK
Clooney
08-01-2002 14:14:31
 Re: How tight? in reply to JD JACK, 07-31-2002 17:04:28
Jack, I haven't ever seen a torque value for the castle nut that holds the 1st reduction gear on [I never torque a nut like that anyhow]. It needs to be tight + a little. Probably about as tight as you can get it with a 1-1/2' wrench or breaker bar then tighten a little more until the cotter pin will go in.
~On the flywheel bolts, they are probably grade 5, 5/8"X11 & I usually tighten about as tight as I can get them with a 1-1/2' to 2' wrench or cheater, or if you want to torque them, probably about 150-160' lbs [dry] or 115-120" lbs [lubricated].....
G Taylor
07-31-2002 19:05:12
What size and grade of bolts/nuts?
JDJACK
07-31-2002 19:48:57
 Re: Re: How tight? in reply to G Taylor, 07-31-2002 19:05:12
I believe that thay are grade 8. Nuts are 7/8 or 15/16, can't remember.
G Taylor
08-01-2002 19:21:16
 Re: Re: Re: How tight? in reply to JDJACK, 07-31-2002 19:48:57
Deere states in a manual for 5/8" grade 8 (five lines on head). 225 ft lbs dry or 160 lubricated. A squirt of engine oil isn't lubrication as it just get squeezed out from between the threads. Cam shaft/lifter assembly lube is required for accurate "lubed" torquing.
