3010 Diesel quits running after one minute
Pat Bryant
07-31-2002 16:28:34
My 3010 would quit running after a very short period of time. So, I was told to drill out the glass ball in the fuel return line going back into the injector pump. It seems to be fixed and back running OK. My question is did I do the right thing becuase the mechanic that told me to drill out the glass ball(after doing so) said that I might have to rebuild the injector pump in two or three years. So, should I try to replace the fitting with the glass ball or what?? Thanks
DEEREMAN
07-31-2002 19:24:50
 Re: 3010 Diesel quits running after one minute in reply to Pat Bryant, 07-31-2002 16:28:34
Sounds to me that the governer ring in the injection pump is breaking up and clogging the return line. It will probably act up again. You need to get the pump rebuilt. Drilling out the ball in the fitting will let debris go into the return line causing engine to stall. Hope this helps
