Clooney-loose flywheel
JD60
07-31-2002 15:45:18
Clooney....I finally had time to be with my 60...I have found from all the drive disk clunking the flywheel is now loose. I bared down but could not budge the nuts..so..any ideas on correcting this..do I have to repair these splines also??? it acts the same way the driver did..
Thanks!!! JD60...
Clooney
08-01-2002 06:36:06
 Re: Clooney-loose flywheel in reply to JD60, 07-31-2002 15:45:18
JD60, without seeing it I can only guess at the wear you have, if the flywheel has ANY rotational movement with the crank not moving with it, you definitely have a problem. The flywheel usually wears first then the crank, so about all you can do is pull the flywheel & see if you can determine how much crank wear you have.
~Even if you have the crank welded you might [probably will] need a new flywheel. ~I'm not sure if there is a taper-lock flywheel for a 60 [probably is] & if the crank isn't worn too bad that might be the way to go. You will have to decide if the crank is good enough to use one. If not you will have to weld & machine your crank or install a new crankshaft & flywheel..
