4010 PTO Help!
Paint Rider
07-31-2002 10:54:38
I just bought a 4010 diesel and am using it to mow with a 8ft brush hog.Every thing is fine in light grass but when I get into moderatley heavy grass it slows down the pto until it finally stops the mower. The engine never pulls down.Is there an adustment for the pto lever which does not snap into place just moves very easily from disenged to engaged.Or an adjustment to the pto clutch if so how do I do it any help would be apprieciated. Thanks Mike
DON
07-31-2002 12:53:41
 Re: 4010 PTO Help! in reply to Paint Rider, 07-31-2002 10:54:38
Open the kick panel and you will see the rod for the pto clutch. It has a turn bucle ,however if memory serves you will have to take the upper end loose so you can shorten it up. There is directions in the operators manual. Shorten untill it pulls pretty hard. Don
paint rider
07-31-2002 13:29:56
 Re: Re: 4010 PTO Help! in reply to DON, 07-31-2002 12:53:41
Thanks Don, took care of the problem. Appreciate your help.
Mike
