'46 B squirts antifreeze from the exhaust manifold bolt!
tom
07-30-2002 17:54:31
I have a 46 B that is squirting antifreeze from the inside exhaust manifold bolt. I would appreciate comments on what I will be dealing with to repair the problem.
This B also fouls the sparkplug on the flywheel side. Any correlation to the antifreeze problem?
Thanks for any input,
Tom
Clooney
07-31-2002 03:24:05
 Re: '46 B squirts antifreeze from the exhaust manifold bolt! in reply to tom, 07-30-2002 17:54:31
Tom, the exhaust manifold stud/bolt holes are drilled into the head coolant area [that is why the original studs use a slightly larger bottom thread diameter to fit tighter].
~You can drain the cooling system down & clean the antifreeze from the bolt & head threads then use a HIGH TEMP sealer on the bolt threads, or remove the antifreeze & use plain water for a few weeks & the leak will probably seal itself up in time, then reinstall the antifreeze.
~On the plug fouling; depends of what it is fouling from [fuel or oil], probably just using a hotter plug or hotter plug & 2 plug gaskets under the plug will go a long ways towards eliminating the fouling problem. If it is fuel fouling, maybe just a leaner carb adjustment will do the trick....
gwh
07-30-2002 19:28:47
Tom, you say manifold bolt,when new it came with studs(easier to keep sealed). I use bolts for convenience but seal them up good while there is no coolant in the threads. One problem with bolts, if they are even a little to long they could perferate the pushrod tubes in the head and cause an internal coolant leak. George
al
07-30-2002 19:14:19
I think you have two problems. The threads around the stud are probably bad, a little perm-a-tex copper could fix it. The fouling plug is probably oil, an indication of rings, try gapping that plug a little more and see if it helps.
Tractorboy
07-30-2002 18:31:10
well it could be a simple fix such as sealing off the bolt or it could be a leaking gasket.
