Rear tires for a 3010
BigMac
07-30-2002 10:01:10
I have a 3010 diesel with 15.5 x 38 rear tires on 14" wide rims. They are a set of Goodyear Dyna Torques that have been run on hard surface and need replacing.
Can I fit a set of 16.9 x 38 tires on those 14" rims or do I need a set of 15" or wider ones? I want to run radials since it is a plow tractor.
Thanks for your responses
BigMac
The Dukester
08-04-2002 13:47:50
 Re: Rear tires for a 3010 in reply to BigMac, 07-30-2002 10:01:10
Well, here's my idea to add to your confusion. Years back a buddy of mine had a Farmall 560 diesel he did a good overhaul on and turbo'd her, and the 15.5's didn't begin to "hold 'er" anymore. So he put on a set of Firestone 16.9's on her and it truly made a different tractor of the 560. I drove it some and just couldn't hardly believe it, it could do so much more! Now really your 4010 probably hasn't got quite the power that 560 had, but I'll just bet you could put a new set of 14.9 Firestones on it and be happy with 'em. 15.5's are good but the small diameter hurts their pulling ability in marginal conditions. If you notice all the newer tractors are using large(42-46 inch) diameter tires of narrower width for row crop aplications, I know, they're fitting them between rows too but the larger diameter tires really work good. 16.9's might be too large for your 4010, but 14.9's oughta be just about right. JMHO
Iowa Farmer
07-30-2002 19:20:38
Hey, I have 16.9.38's on my 4010 and they are almost too much for it. The 3 pt will not get as low as it should and I have had problems trying to hitch up 3pt implements. My bet would be to stay with the 15.5's.
Mike Aylward
07-30-2002 10:48:25
BigMac, the "factory recommended" rim for a 16.9 tire is 15" but you can install them on a 14" rim with little trouble. However, a 16.9-38 is a whole lot of tire for a 3010. If you are going to be using a lot of three-point equipment you might (and I emphasize might) run into some clearance problems as the diameter of the 16.9 tires is quite a bit bigger. You may need to install a quick hitch for tire clearance on some implements. Also, if you are going to run single tires instead of duals most of the time you will see some "swim" in the tractor with the radials on the highway. Powerwise, if your 3010 is "healthy" you will get along just fine, but keep these limitations in mind. Some things to think about. Mike
BigMac
07-30-2002 11:19:10
 Re: Re: Rear tires for a 3010 in reply to Mike Aylward, 07-30-2002 10:48:25
Does anyone make a size between the 15.5 and 16.9? I have seen 16.3 tires before but it has been awhile.
JDJIM
07-30-2002 20:20:55
 Re: Re: Re: Rear tires for a 3010 in reply to BigMac, 07-30-2002 11:19:10
They make a 14.9x38 which is the same as the old 13x38 , it is supposed to go on a 13" rim , don't know how it'd work on the 14" eims . It is a little lower than the 16.9 tire . I just put a set of 16.9x38's in place of 15.5's on my 3020D , used the old 14" rims . The tire man said they did that a lot . They are quite a bit higher than the old 15.5's I think abour 2-2 1/2 inches at the axle . I didn't notice any 3pt problem , I don't do any heavy field work with it so I can't say about power . I put 10.00x16's on the front because I have a loader on it , the tractor sits almost level , looks pretty good .
BigMac,
07-31-2002 05:02:36
 Re: Re: Re: Re: Rear tires for a 3010 in reply to JDJIM, 07-30-2002 20:20:55
Jim,
I have 7.50-16 tires on the front of my 3010. My worn down 15.5-38 rears stand only 58" tall making the tractor look like it is sitting in a hole. The Goodyear sizing chart for the Dyna Torque II says that the 15.5 tire should stand 62.2" tall. I've been robbed of 4 inches by the previous owner.
You state you have no 3pt problems with the 66.6" tall 16.9 tire yet others say they do. Since this is a tillage tractor(4 bottom 3pt plow amd 8ft 3pt disk) would you recommend staying with 15.5 or going up to 16.9?
BigMac
Dr. Evil
07-31-2002 08:43:35
 Re: Re: Re: Re: Re: Rear tires for a 3010 in reply to BigMac,, 07-31-2002 05:02:36
To go to the 16.9 from the worn out 15.5's You have will increase your speed in each gear 15%!!! New 15.5 tires will get You back to about a 7% increase which isn't real noticable. With the 16.9's I would almost bet You have to run a gear slower or drop down to a 3 bottom plow. With the difference in $$$ and what it will do to the performance of Your little 3010, I'd stick with the 15.5's. A LOT of 4010/4020's got worn out with 15.5's
BigMac - Thanks Dr. Evil
07-31-2002 12:27:42
 Re: Re: Re: Re: Re: Re: Rear tires for a 3010 in reply to Dr. Evil, 07-31-2002 08:43:35
Doctor, or do you prefer Evil,
That is the most profound, scientific, well thought out answer this Hillbilly Whitetrash Redneck could ever have asked for. Hope you did'nt burn up your sliderule cipherin that out.
Thank you very much. Going to put a set of 15.5 Dyna Torque II skins on that bad boy and spend the next 20 years wearing them out.
Thanks everyone for your input.
BigMac
Dr. Evil
07-31-2002 14:25:09
 Re: Re: Re: Re: Re: Re: Re: Rear tires for a 3010 in reply to BigMac - Thanks Dr. Evil, 07-31-2002 12:27:42
I used my calculator here from work..... I'd think about using FIRESTONE tires myself.... Good Years are O-K but NOT as good as the FIrestone Radial or 23 Deg. All Traction Field & Road's.
gy3020
07-31-2002 13:36:56
Hi BigMac,
Just wanted to put in a little on this. I agree with your choice to stay with te 15.5-38's, I have a 3020 that I put a new set of dyna-torques on back in 99 and have did alot of running with them. Its a custom hay baling tractor so its seen alot of road travel. Tires still look pretty darn good. Just got a 65 model 4020 a couple of weeks ago and its got 16.9-34's on it. Big ole tires!
