Trouble With JD 125 Skidsteer Hydraulics
KEVIN L
07-29-2002 15:35:48
I got the leak fixed and when up on blocks everything works fine, When I put it on the ground it only moves forward and back but will not turn in either direction, just makes that sound like if you raise a cyl to its stop and dont let go of the lever, Any ideas, bad pump? or stuck relief valve, or? if so which one it has 4 Thanks for any info..
Brokenwrench
07-30-2002 09:10:00
 Re: Trouble With JD 125 Skidsteer Hydraulics in reply to KEVIN L, 07-29-2002 15:35:48
My suggestion would be to buy the service manual for the machine and test guages and the necessary fittings to test the pressures if you want to attempt to test the unit yourself. There are too many variables involved to try to guess your way through the hydro. system on a ssl.
KEVIN L
07-30-2002 15:16:31
 Re: Re: Trouble With JD 125 Skidsteer Hydraulics in reply to Brokenwrench, 07-30-2002 09:10:00
Thanks brokenwrench, the manual came with it and my next step is to get a pressure gauge and start looking for the trouble, Just thought Id see if anyone has had similar experiences with the same unit, by the way does anyone know of any junkyards that specialize in skidloaders in the midwest? I am located in wisconsin. Thanks
