Power Lift to Powertrol on a 46B?
Sam Vastano
07-29-2002 07:12:58
Right now my 46 B has power lift. I have a 3 point setup and it works ok but I would like to have the ability to feather my snow blade in the winter. Is it a big job to convert over to the power-trol? I was told long ago it is a matter of unbolting the power lift unit and bolting up the power-trol??? Is this correct?
Thanks
Sam
Jerry S
07-29-2002 12:50:44
 Re: Power Lift to Powertrol on a 46B? in reply to Sam Vastano, 07-29-2002 07:12:58
I did this kind of change on a 48 A and a couple things to be careful of is that your housing is made with a round hole on the lower right where the valve body goes on. That fits a spring that is not present in the powerlift version. There is also one bolt that has a copper washer on it I believe on the upper left. That holds pressure so be sure you don't use the wrong bolt there. Otherwise, you will probably want a new gasket but should only take a few minutes to change the 7 bolts.
ChuckW
07-29-2002 09:40:59
yes, If I were replacing, I would find the later model Powertrol used on 51-52 B's.
ChuckW
07-29-2002 08:25:26
I believe the whole unit is interchangable, so I would say you could replace the power lift with the powertrol unit. The powertrol is basically a levered control unit.
Sam Vastano
07-29-2002 09:20:00
 Re: Re: Power Lift to Powertrol on a 46B? in reply to ChuckW, 07-29-2002 08:25:26
Will that also give me the ability of a remote cylinder?
Thanks
Sam
YES
07-29-2002 10:33:55
 Re: Re: Re: Power Lift to Powertrol on a 46B? in reply to Sam Vastano, 07-29-2002 09:20:00
it will
