Jd310b backhoe/loader hydrolic pump solenoid?????
george
07-27-2002 20:04:50
could anyone tell me what the solenoid function is on the drivers/left side of the hydrolic pump and at what time should it be energised . i just got her and have not yet ordered a repair manual thanks
Jonathan
07-28-2002 04:07:54
 Re: jd310b backhoe/loader hydrolic pump solenoid????? in reply to george, 07-27-2002 20:04:50
As the other gentleman said, it keeps the pump from building pressure while starting. Its only energized when the starter is turning. If it starts like you have weak batteries and when you pull a backhoe lever (bucket curl, stabilizer down etc.) and it cranks easier , it points to a solenoid problem. (Pulling a backhoe function lever keeps the pump from building pressure also.)
Matthew
07-27-2002 20:23:31
Keeps pump from building pressure while starting engine.
