Hub assys on 40T
KB
07-27-2002 17:35:23
I have yet again had to tighten the wheel hubs on the axle of our 40T. This seems to be a yearly thing with this tractor. Today when I tighten them I broke two of them off. I replaced all 4 with Grade 8 bolts today and got them as tight as I could as well as replaced the key on the axle. I am western PA and this tractor spends most of it's time on the side of a hill does this have something to do with it or is this just the way this tractor is? Should I inspect something specific? I didn't notice anything wrong when I was working on it today.
Wayne in Tn.
07-27-2002 18:02:16
 Re: Hub assys on 40T in reply to KB, 07-27-2002 17:35:23
KB, yes you are correct, the hillsides are hard on those hubs. That is all you can do, is try to keep them tight as possible. Tighten all 4 a little at a time. Also the hub and the cap are eaisly broken if run loose. They are getting harder to find in the junkyards also. You might inspect the cap and hub to be sure there are no cracks. I have had the wheel to fall completely off while bushogging on a hillside, scary feeling.
