JD 310b backhoe info
gcobb
12-18-2003 06:01:29
I just bought a john deere backhoe 310b with a rod thru the block. The Frame Plate says "310B-191246T" The Motor Plate says
"5164DT 03" With the word "type" above it and "281325T" With the word "serial" above it.
The block has R55110,R55120, R55200, R55240 cast into it on the right side. Can anyone tell me year motor size Etc. and where can I find used parts. like a rod, bare block, or after market rebuild kits etc.
Thanks in advance!
This is a real nice backhoe. and was a daily worker untill a teenager stole it and ran it down the high way in low range wide open untill the rod came loose.
Brokenwrench
12-18-2003 16:43:52
 Re: JD 310b backhoe info in reply to gcobb, 12-18-2003 06:01:29
Tractor should have 219 engine,it is a very common engine. Most salvage yards should have one. They were used in 2020,2520,2440,and many industrial applications such as air compressors,pumps and generators. You can also use a 239naturally aspirated or turbocharged in its place if you want alittle more HP.
gcobb
12-19-2003 04:05:46
 Re: Re: JD 310b backhoe info in reply to Brokenwrench, 12-18-2003 16:43:52
Thanks! I appreciate any and all information!
