Have problems with PTO clutch on my R
Steve
07-26-2002 18:28:40
I was hoping someone could email me a exploded view of the pto/clutch assembly for a model R. It grinds when I try to engage the the pto. I tried to adjust it according to the factory owners manual, but I think I have more serious problems that will require disassembly.
Thanks
Steve from Michigan
Gord
07-26-2002 20:26:16
 Re: Have problems with PTO clutch on my R in reply to Steve, 07-26-2002 18:28:40
Steve, with the tractor shut off and the PTO lever pushed ahead to engage, try turning the PTO shaft by hand. It should not turn at all. If it does and the clutches are compressed in the PTO itself then you could have a serious problem with the right angle drive gears in the front of the transmission itself, or it could be what's called the internal gear that drives the PTO shaft itself is missing some teeth. Either way, by the sounds of it you should get the manual from Deere and get it out and checked over real good before it really explodes!!
Good luck, Gord.
