2030 Load Shaft
very bad leaks- Question before repair
Barney-South Ga
07-26-2002 05:31:41
My neighbor saw that my 3020 load control shaft replacement project was a success and has asked me to fix his 1972 2030. Two resons my 3020 is fixed today is : 1. Everyone's help in here-THANKS!
2. Boling Machine Shop- Thanks Steve!
Before I tear the 2030 down I need to find out from someone if these leaks can be fixed the same way-by replacing the load control shaft and seals/bushing. If so I need to know if there are any differences between the replacement procedure for these two different models and if so I hope someone that has done a 2030 will shed some light on this for me. My neighbor doesn't have a shop manual for the 2030.
Thanks in Advance Everyone! Barney
HTR
07-26-2002 10:50:41
 Re: 2030 Load Shaft - very bad leaks- Question before repair in reply to Barney-South Ga., 07-26-2002 05:31:41
The 2030 tractors don't have the same problem as the 3020. They already have the Oring, teflon ring type seal. Unless the shaft or bushings are drastically worn, just replacing the Oring and teflon will cure the problem.
