Sticking vavle on 730 LP Engine
Ben.So.Tex
07-25-2002 18:49:24
If I let my 730LP idle for a few mintues and then troddle up it sound like it has a sticking vavle, If I pull back on the troddle and the advance it slowly it clear up, So my question is,, how do I get some two cycle oil into the engine intake to see if might unstick the vavle,,,I have not checked the plugs to see if they might need regapping, or points or cap..
Thanks Clooney/
07-26-2002 14:18:07
 Re: Sticking vavle on 730 LP Engine in reply to Ben.So.Tex, 07-25-2002 18:49:24
Thanks Clooney, I will be heading to the ranch and give it a try. BEN
Clooney
07-26-2002 03:51:43
Ben, pull the rocker cover & make sure you don't have tight valves [adjust the valves].
~Then push on the valves to see if one sticks.
~At that time you can manually oil the valve stems & blow the oil in farther with compressed air. ~While the rocker cover is off, crank the engine & make sure you have oil coming from the rocker oiling pipe....
