Clooney update on 90 on front wheel lug nuts.
44 Styled B
12-17-2003 20:19:04
While flipping thru the pages of the John Deere service manual for my 1944 B I found a photo showing the front lug nuts just like the ones on mine with a "90" right in the center of the lug nut. Page 160-5-3 Figure 160-5-11 the photo is very light but I can make out a "90" in the center of the stud. I guess John Deere's supplier sold a lot of these to many different companies. I'm trying to restore mine to as near original as possible. Researching is part of the fun in restoration.
Clooney
12-18-2003 06:11:13
 Re: Clooney update on 90 on front wheel lug nuts. in reply to 44 Styled B, 12-17-2003 20:19:04
44 Styled B, thanks for the follow up.. I know a lot of my 2-cylinder's have those bolts on them.
~And thanks to Duane we know Deere didn't use those numbers as a toque value.
~I doubt Deere made their own lug bolts so they probably came from a bolt supplier.. Those numbers were probably used on one of the other users of those bolts.
[email protected]
Duane Larson
12-17-2003 21:31:29
44 Styled B,
Nice piece of detective work! Various Field Service Bulletins all give values of 60 ft-lbs for front wheel bolt torques, and 100 ft-lbs for rear pressed steel wheels. So, the 90 must be a manufacturer's stamp rather than the tightening torque.
If you have reversible front wheels (JD1262, after B153376) the bolt part number is JD19R (mfg # 31940), and non-reversible front wheels used bolt JD17R (mfg # 05163, indented head). But again there is no reference to 90. So, I guess it remains a mystery (to me, at least).
