JD 2130 oil light?
DerekD
07-25-2002 18:27:11
My oil light on the 2130 will come on when at medium to high RPM's. When idling or low RPM the light goes off. Oil level is fine. Could it be a bad sensor? Any suggestions greatly appreciated.
davidval
07-26-2002 14:07:13
 Re: JD 2130 oil light? in reply to DerekD, 07-25-2002 18:27:11
whenever there is a possible problem with oil pressure ALWAYS check pressure with a good gage to eliminate the possibility of a real oil pressure problem that can destroy the engine.david
Alton
07-25-2002 18:55:43
It could be a bad sensor. You can get an pressure gauge and test it, but probally buy a sensor cheaper.
