? tierods for 430 435
Alvin NE WI
12-17-2003 19:43:37
Are the tie rods and ends for the 430 and 435 the same?
Clooney
12-18-2003 05:54:43
 Re: ? tierods for 430 435 in reply to Alvin NE WI, 12-17-2003 19:43:37
Alvin, a qualified yes,, as long as the front axles are the same type they use the same outer ends... Each axle [type] does seem to use a different outer tie rod end though.. The 420-430 [depending on model] does use many different front axles... Now on the inner tie rod ends, almost all seem to use the same AM 496T inner tie rod end..
~If you can give us the axle type & tractor model on each tractor we can give you the part number for the inner & outer tie rod ends for each tractor.. OR, let us know what front axle the 435 has & we can tell you what model/axle of 420-430 tractors used the same parts...
~If you are just looking for tied rod ends that work, take your old tie rod to your local auto parts store. In a lot of cases they can match one up that will work. Especially the inners.. On those long adjustable outers I doubt they will match those up...
[email protected]
MIKE HANLEY
12-17-2003 20:39:50
Yes no and maybe. The 430 had differant tierods for the differant models, ( T W U V etc) They were all straight (as opposesd to the square axel Waterloo WF's that had two bends) and were ajustable. So the question becames do you want a factory look, or something that will work. The tie rod ends (balljoints) for a square axel Waterloo WF's is the same as what JD used on the 1065 and later wagons. (about $23.00 each.)
