52 B petcocks
Greg
07-24-2002 06:16:42
I have a 52 B that has 2 petcocks next to each other located under and near the front of the motor, what is the purpose of these petcocks.
ChuckW
07-25-2002 04:54:48
 Re: 52 B petcocks in reply to Greg, 07-24-2002 06:16:42
The pitcocks served two purposes, release fuel to clear the cylinder, plus enabled the operator to hand crank the tractor. If you've ever tried to turn one over by hand, late model B with the cyclone head you can see what I mean. The operator had a special shaft that attached to the steering wheel, by removing the small section of the flywheel cover you could hand crank. This made it easier to crank plus eliminated some of the kickback.
Clooney
07-24-2002 06:50:59
Greg, the main purpose of those petcocks is to retain oil so you get a puff of blue smoke when the engine is put under load after idling for a while. [well not really, but they will do that].
~Actually those petcocks were added by someone, probably as a cylinder drain if the engine flooded. The tractor came with pipe plugs in those holes.
Dave K (FL)
07-24-2002 17:14:01
 Re: Re: 52 B petcocks in reply to Clooney, 07-24-2002 06:50:59
Wouldn't those be the compression release cocks? My 48 A has the release cocks there. I keep them open when not running in case gas happens to leak down into the cyls.
Dave
gwh
07-24-2002 20:35:45
 Re: Re: Re: 52 B petcocks in reply to Dave K (FL), 07-24-2002 17:14:01
Dave, Just before the start of 1952 production of A's & B's the comp. relief cocks were substituted w/pipe plugs. They could be installed later by the owner if needed.
