730 TAPERLOCK FLYWHEEL
JOHN COLLINS
07-23-2002 21:59:42
Can any body help me with where i can buy a new taperlock flywheel for a 730 jd
guy
07-26-2002 09:08:18
 Re: 730 TAPERLOCK FLYWHEEL in reply to JOHN COLLINS, 07-23-2002 21:59:42
In October 2000 I got a 720 diesel just becuse I always liked green and wanted a big 2 cyl diesel.
It was kinda rough, but the price was reasonable, and I want to use it more than show anyway.
It was quiet when I got it, but quickly got noisy. I found the flywheel loose. Not sloppy loose, just chucking.
I cleaned and torqued the bolts and it was quiet again, for about 30 minutes.
After checking the prices, I said "what the H---", cleaned the splines and put it back on with some devcon two part epoxy. My 720 does not use the flywheel to set crank end play, so I didn't have to worry about that.
I now have at least 20 HARD hours on it and it is still tight.
Hope I never have to get it off. If I do, I'll make a big puller attaching to the pinch bolt holes and beat and heat until something gives.
This probably won't work if it is too worn, but at least if it loosens again it'll be easy to get off.
Good luck
MIKE HANLEY
07-24-2002 22:39:55
Denglers in Middletown Ohio phone 1-513-423-4000 will sleve your old flywheel with the lock tite hub or sell you a new one ready to put on. We have had one on a 730D for about 6 years now. Belive it or not you sledge it on with a 16# mall. And to get it off you sledge it with a 16# mall. They will send instructions. Freight is big bucks.
Seamo
07-24-2002 05:00:18
John ,Where do you live? I see several ads in Green mag And 2cyl mag. Earl
john collins
07-24-2002 18:50:34
 Re: Re: 730 TAPERLOCK FLYWHEEL in reply to Seamo, 07-24-2002 05:00:18
i live in australia i would like to contact the people in usa that build the new flywheels.
Seamo
07-24-2002 20:43:04
 Re: Re: Re: 730 TAPERLOCK FLYWHEEL in reply to john collins, 07-24-2002 18:50:34
John I am not for sure but I believe that they are NOT new flywheels. Maybe someone will reply that has used one. They tell me that its a industrial type hub that they machine and put in the old flywheel. Earl
