John Deere 70
Ben
12-17-2003 15:30:13
want information on rod bearings and knocking. tractor has new pistons and rings when fired up it knocks.
Clooney
12-17-2003 18:17:20
 Re: John Deere 70 in reply to Ben, 12-17-2003 15:30:13
Ben, that could be almost anything..
~Start with the obvious & easy to get at things..
~First make sure the flywheel is tight [a major cause of knocking on a 70]..
~Then make sure the clutch driver is tight on the crank splines [another major cause of knocking in a 70]..
~If engaging & disengaging the clutch changes the noise suspect a flywheel or clutch driver..
~If the noise is internal short out 1 cylinder at a time & see if you can identify the cylinder..
~You will probably have to at least pull the crankcase cover & give the rods a shake, then maybe go in farther..
~Can you tell if the noise is once per rev [revolution] or every other rev?..
~Give us some more data on the noise.. Under load? Hot? Cold? All gears? Clutch in or out? Where does it seem to come from [use a piece of hose up to your ear & probe around]..
[email protected]
buickanddeere
12-17-2003 17:51:25
When we freshened the 70D engine with 45 over bore,re-timed injection pump,fresh injectors, new valves,seats and reground cam we thought there was something wrong with it at 1st too. We were not used to the sharp "knock" sound of diesel combustion compaired to the mushy putt it used to have.
Gman
12-17-2003 17:19:40
Ben I went thru my 70 std.new rings and pistons(old ones cracked in shirt) didn't bore it,but when I fired it up I got a knocking noise coming from from area just before block bolts to case. I tore engine down sleeve block back to fit pistons I had already purchased,put the same rings back in and engine was quite,apparently the cylinders were distorted out of round enough to get some piston slap,now I'm not recomending this as could be your problem but just a start,if its not a show tractor I'd run it Gmans two cents worth
Steve Eberly
12-31-2003 10:53:45
 Re: Re: John Deere 70 in reply to Gman, 12-17-2003 17:19:40
Years ago we did the same thing. Ours is a diesel. We removed and re-tightend the flywheel and still had the knock. What we eventually found was the there is a bevel gear on the crankshaft(same side as the flywheel)this gear had just enough slap on the key(keyed into flywheel) that we were getting the knock. We replaced the gear and key and all was fine. We kept the old gear because it drove us crazy trying to find the knock. good luck!
