1020 CARB
MARK
07-21-2002 23:28:22
Does anyone have any info on this carb.
I have completely cleaned this thing but couldn't get the small jet out of it. Any suggestions for removing it. I think it's the only thing keeping this thing from running off it's own fuel delivery system. The pump is working and needle and seat are perfect, as is the float. I have to manually squirt gas in the carbeurator to make it run and keep squirting to keep it running. Also the radiator is pretty screwed up. I heard from someone that this original radiator for this tractor came from a chrysler car, is this true?
Does anyone have a layout for the internal passages for this carb?
Thanks
Mark
blan
08-12-2004 21:39:24
 Re: 1020 CARB in reply to MARK, 07-21-2002 23:28:22
i just had the same problem w/my 1020 i took the carb off disasembled it took the rod holding the float on out removed the float took the jet pin ? out took off the inlet elbow and blew through the jet hole and a small piece of trash came out. the tractor fired up no problem. hope this helps
