44 Model A fluids
J Lashbrook
07-21-2002 22:32:23
I was wondering what type of oil I should use in my motor, rearend, and lift. Thanks, James
Clooney
07-22-2002 03:34:29
 Re: 44 Model A fluids in reply to J Lashbrook, 07-21-2002 22:32:23
J Lashbrook, for motor oil it depends on the type of previous oil that was used. If the tractor has used non-detergent for years you should either stay with the non-detergent or clean the crankcase, oil pump screen & rocker area of crud before switching to the newer detergent type. As for the weight? That depends on engine wear, type of usage & other factors. If in doubt on the wear history use straight 30 weight in the summer & switch to a 20 weight or 10W30 for the winter.
~About the same advice for the trans/rear end. It depends on the wear & expected usage. If the gears & bearings have some wear on them [a 44 probably does] & the expected usage is mostly summer then 140 weight GL-1 [hard to find the GL-1 anymore, Chevron still makes it in their RPM series], if the usage includes some work hours at temps below 20*F then 90 weight GL-1 should be used, [will make more noise but you will be able to shift it in cold weather]..
~On the power-lift or power-trol: there again it depends on the wear & temperatures it is used at. Try 20 weight & if no winter use expected or if it quits operating when it gets hot switch to 30 weight.
~Keep in mind this is just my opinion & it seems almost everybody has a different one on the oil issue so read it all & use what you believe in.
