Synthetic Oil
Barry
07-21-2002 16:55:09
Just had my 51 B engine redone, need some input on using 10-30 synthetic oil in it vs. straight 30.
If you have a smart remark or comment please keep it to yourself. Thx BB
Steve - IN
07-22-2002 15:36:31
 Re: Synthetic Oil in reply to Barry, 07-21-2002 16:55:09
Other guys who turn wrenches on other kinds of engines have these kinds of discussions as well. I found what has to be the most comprehensive list of everything that's WRONG with synthetic motor oils on a British bikers list. Recommended reading, via the link below, as it might be time for some levity in this discussion.
Here's another link, which gives some Federally funded research / testing on synthetics. http://p2library.nfesc.navy.mil/P2_Opportunity_Handbook/6_II_4.html
What I gather from all the above is the following syllogism: Synthetic oil reduces bearing friction better at extremely high temps and extremely low temps. Friction is bad. Therefore synthetics are good. Simple, huh?
Another interesting tidbit I picked up was that old manuals recommending non detergent oils did so because old detergent oils used something akin to Ajax for their detergent properties. So the better way to reduce friction was with non detergent oil -- friction reduction being the primary reason for using any oil.
Steve
Doug in OR
07-22-2002 18:42:44
 Re: Re: Synthetic Oil in reply to Steve - IN, 07-22-2002 15:36:31
Thanks, Steve! I like to find my info via good, solid research, and appreciate you posting the web site. I work with several mechanics, and I see the full gammut of thoughts on oils. Generally, I've noted that the philosophy they hold is the one they learned when they were apprentices. Too bad we all get old and are hesitant change our ideas when something newer and better comes along.
And Barry - I'm sorry if we spoiled your thread on the legitimate question of using Mobil-1 in your B. Rest assured, you will do it no harm. It will probably even help.
As for the motorcycle synthetic page, be careful - there might be one or two readers here who will actually believe that one! LOL!!
As a further note: They cured the detergency problem when they switched from Ajax to Bon Ami, eh Steve? -smile-
With that, I bow out of this discussion.
Steve - IN
07-22-2002 21:01:20
 Re: Re: Re: Synthetic Oil in reply to Doug in OR, 07-22-2002 18:42:44
Doug,
Too many good snippets in your post to resist.
I've got a sign, late of my garage, now my barn, which reads: "Don't assume. Check it out." Probably good words to live by. Then again, I also have a sign that reads: "NO SNIVELING" JJ's Cantina, Cholla Bay Mexico.
Mobil says they discovered / invented synthetic oil in 1949. But then I read that synthetic oils were first used in the first jets. (they could hold up to the intense heat on the main shaft). That leads to Whittle in 1936, the first jet engine -- or to the Jumo or BMW jets in Messerschmidt 262's and Heinkels, the first operational jets. Probably more likely, as the WWII Germans were in to synthesizing anything to replace crude oil petroleum. Anyway, it's not something totally new unless you consider 50 years or so new.
Barry, there used to be a disgusting saying among the crude elements of oval track and road racing that went something like: "like giving an enema to a dead man, probably won't help, but ain't gonna hurt nothing." I'd rank synthetic oils far above that, but worst case, "ain't gonna hurt" is your fall back.
Those Brit bikers don't lie, do they?
Thanks for setting me straight on the Bon Ami. I thought it might be Comet cleanser.
Whatever you decide on the oil, Barry, change it and the filter like they vote in Chicago: early and often.
Steve
Doug in OR
07-22-2002 22:02:19
 Re: Re: Re: Re: Synthetic Oil in reply to Steve - IN, 07-22-2002 21:01:20
Again.. need to put my two cents worth in.
The Germans used synthetics back in WWII when petroleum was in short supply. The Brits used it in their first jets, as we did too. Again, conventional oils couldn't stand up to the demands of jet engine service. Even today, with the advances in mineral oils, you'll find that synthetics haven't been replaced in these aviation uses - synthetics have only gotten better.
Mobil and AMSOIL introduced synthetics to the general consumer market in 1973. Both oils were 25,000 mile oils. Mobil backed off, but AMSOIL kept plugging away at it. Mobil got back into the market - though I'm not certain when. Mobil no longer claims their oil will go 25,000 miles. I don't know if this is because of marketing ploys, or if they reduced the TBN (total base number) of their oil. That's one item they leave off their spec sheet. Even with extended drain intervals, you need to change the filters at the usual intervals. They may have just assumed that the general public wouldn't do one without doing the other.
An interesting side note here is that in Europe, as I understand it, they specify approximately 9,000 miles (actual number is 15,000 km) as the prescribed change interval. I've heard that they want to move that up to about 15,000 miles. They're doing this for several reasons - but mostly because of oil conservation and environmental conservation issues. They are very much into synthetic development over there.
The oil companies are seeing the writing on the wall. Everyone is getting into it now. It might not happen in my lifetime, but I believe that all motor oils will be synthetic within the next 30 years.
Brian
07-22-2002 12:25:05
I don't claim to know anything about engine oil so I asked our oil expert at work who analyzes the oil samples removed from our stationary engines and he said not to use synthetic oil in pre 1950 engines. He gave me a web site to read and said it does a good job of explaining the issue.
G-MAN
07-22-2002 13:26:55
 Re: Re: Synthetic Oil in reply to Brian, 07-22-2002 12:25:05
I have to agree with Doug on this one - sounds like another "motor myth" to me. I can sort of understand the theory of not using it in older engines (loose tolerances, old seals and all that other b.s.), but why the 1950 cut-off point? Is that supposed to mean that you can use synthetic oil in your 1951 JD B, but not your 1949 JD A? Makes no sense to me. Doug has another excellent point on the oil additives part of the discussion. I was told by an engine expert that the oil additives are the greatest thing in the world - just leave them in the can and they'll do everything they advertise. Do people really think that if there were these miracle ingredients that could fix leaks, restore compression and whatever else, that the oil companies wouldn't put them in the oil in the first place and charge more? BTW - I am driving a 1990 Pontiac Grand Am that has been pretty much beaten unmercifully at times while running Castrol GTX 5W-30 petroleum oil (I can't remember when I changed it last), and it will turn 220,000 miles this weekend - still runs good. What is more important than the type of oil used, is to follow the proper service intervals and guidelines.
Doug in OR
07-22-2002 13:17:29
Interesting. But I've never seen so many Urban Legends in a single article. First of all, that motor oil commercial was with Havoline Oil, back in the 60's - well before anyone was making synthetics for a car! I still remember that commercial - I was knee high to a grasshopper. And I'm not the youngest guy who visits here. One other "miracle additive" company was doing that same gimmick on small engines. They were letting the engines run without oils at various State and Local fairs. When an independent tester did the same thing, the engines ran fine - for the prescribed amount of time - but they were a mess when they tore down the engine and checked for wear.
Neutralizing sulphur in diesel trucks? I've got news for anyone who thinks you'll find much sulphur in today's diesel fuel. The EPA "fixed" that. Particulate matter is the biggest culprit that oils need to deal with in diesel engines. Followed next by the acids. It looked almost like a circa 1965 article. I wonder how much the author of that article really knew about oil?
That (fancy name) zinc additive? Yep, that's what it does. Some racing oils use it, but it serves mostly as a last-ditch mechanism against wear in some very high RPM engines - when there are moments when the oil can't be replenished to all moving parts fast enough. I'm not interested in running my car, truck, or tractor to the point of oil starvation. I could care less about the zinc additive. Newer oils have better ways of preventing friction and wear. Besides, the zinc additive he speaks of is very toxic.
I'll agree that you might get seal leakage if you start using a detergent oil after switching from a non-detergent oil. But this is mainly due to the fact that the crud itself was preventing the seal from leaking. I wouldn't expect this to be the case in a newly rebuilt engine - which was the reason for the original post.
Older oils were better than newer oils? Go ahead - run some grade SA or non-detergent oil in your 2002 Mercedes. They'll laugh you out of the shop when you bring it in for warranty repairs.
Brian
07-22-2002 14:37:31
 Re: Re: Re: Synthetic Oil in reply to Doug in OR, 07-22-2002 13:17:29
Yep you convinced me you obviously know more about oil than our oil chemist with 35 years of experience. I am going right out and buy all the synthetic oil I can find and change all my tractors to synthetic. Might even put some in my wife's vacuum cleaner might make it rev to 8000 and last 5000 hours.
BTW how many tractor engines have you built and run for 5000 hours before a major?
ErnieD
07-22-2002 17:19:39
 Re: Re: Re: Re: Synthetic Oil in reply to Brian, 07-22-2002 14:37:31
We got 9500 hours on a Ford 851 before it had it had it bottom end rebuilt. The top had 3 valve jobs. We owned it from 600 hours on. Cylinder compression was down to 45-60 psi.
Jerry S
07-22-2002 11:03:26
I haven't used synthetic oil yet but my boss did on a mid 90's GMC 3/4T truck motor. Had 80K on it and when they took the motor out to fix it, found the oil gelled up so it trashed the whole motor. He was using the mobile 1 synthetic I believe. I am real curious as to what caused that.
Doug in OR
07-22-2002 11:53:56
 Re: Re: Synthetic Oil in reply to Jerry S, 07-22-2002 11:03:26
I won't speculate as to what would cause this. It could have been a water leak. I just wonder if he used an additive or something. I know I'm going catch heck for saying this.. but here goes... Just Say No To Oil Additives!
The additive packages of modern oils, and I'm speaking of all oils, not just synthetics, are engineered to work together as a complete package. You never know what some of these other additives have in them. I assure you that if you call the maunfacturer, you'll get an answer along the lines of, "it's our own wonderful proprietary ingredients".
I've seen where regular cars and small trucks, using synthetic oils, have easily gone 300,000+ miles.
I assume that Mobil warrants their oils, as does the manufacturer of the synthetics I use. Hopefully, this oil was sent in for analysis.
Doug in OR
07-22-2002 07:48:10
I usually don't hang in this forum... but I noticed the topic on the general page...
Synthetics are far superior to conventional motor oils. A 10w (though they don't make that viscosity in synthetic) is far better than the SAE 30 grade oils of 50 years ago. And despite what others may tell you, you will get better protection with a 10w-30 oil than you will with a straight 30 oil. It's how the oil performs when it is cold that really kills or save an engine. Tests indicate that over 80% of all engine wear happens during engine warmup. Synthetic oils flow much better than conventional oils - especially when cold.
Having said the above, I'll make one point... a tractor engine doesn't take the beating that a car engine does. You have far fewer RPMs and lower operating temperatures. You do have considerably more dirt in the environment - but a high-quality air filter will help you here more than the oil. That goes for an oil filter too. It's the dirt in the oil that causes the wear - get the highest quality oil filter you can find. That "name brand" filter that you've seen advertised on tv is *way* down on the list for filtering capacity and capability. Do some research there.
Synthetics won't harm your engine at all. Although you won't get the real benefits using them in a tractor - as opposed to using them in a car.
G-MAN
07-22-2002 09:40:38
 Re: Re: Synthetic Oil in reply to Doug in OR, 07-22-2002 07:48:10
You have a lot of good points, Doug, but I have to disagree with you in a couple areas. In general, tractor engines take far more abuse than do car engines, providing they're used as they were intended. A restored tractor doing parade duty may not get worked hard, but a lot of the two-cylinders that are still used daily definitely do. The old all-fuel tractors were designed to operate at high temperatures - around 200 degrees or more to properly vaporize the fuel for good combustion - this while being cooled by plain water in most cases, without the benefit of corrosion inhibitors, and without oils with detergents to prevent sludge build up and keep parts clean and free. The air filters were of the oil bath type, which although they work decent, required daily maintenance in dirty conditions, which few received. Add that to being pulled down to rated RPM for hours on end while plowing and other heavy work, daily cold start-ups before the days of multi-viscosity oils and block heaters, fuel dilution if not operated at full temp, prolonged periods of near idle conditions when doing light PTO or belt work, and many other difficult operating conditions and you have an engine that is basically abused on a daily basis. There aren't many cars that have to be started at 10 degrees to go feed the livestock every morning for the entire winter, the way those old tractors did. The beauty is that most of those engines and tractors tolerated the abuse for decades - far longer than most cars last. I also believe there are advantages to the synthetic oil - that apply to all engines, and maybe more so to these old tractor engines. When you're dealing with an engine that makes a whopping 25 horsepower, even picking up a little horsepower makes a big difference, not to mention the added benefits of less friction, wear and heat.
Steve - IN
07-21-2002 23:32:55
Barry,
I use synthetics. Have for years. The molecular chains are consistent in synthetics so you get more consistent and therefore better lubrication than with petro oils composed of long, short and medium chain molecules.
In my old JD's I use Mobil 1 10w-30 -- the type formulated for older engines. There's a different additive package in this version, primarily composed of esther, which plugs old gaskets and seals just like a petro oil does.
As for break in, I'll just quote the following from Motor Magazine, founded 1903. Feb. 2000 issue, link below.
"There's not a shred of evidence to suggest that synthetic motor oils delay or prevent piston ring break-in. Maxwell speculates that the rumor got started when synthetics first came to market, and attributes it to the psyche of consumers using the new product for the first time. Remember, back in the mid-'70s conventional oil sold for about 69 cents a can. Synthetics, on the other hand, came in at a hefty 4 bucks a pop. To justify spending so much more, consumers frequently checked the oil level of their new vehicles as if expecting to see some sort of miraculous benefit. What they found instead was a crankcase down a quart of oil, which they attributed to the synthetic. In reality, losing a quart of oil during break-in was standard fare on engines of this era, regardless of the type of oil used. Unfortunately, synthetics got the blame. And they're still trying to live it down.
That's what I've read. Here's what I know from hands on experience. I raced for a lot of years. Usually built 6 or so engines a year. Very, very loose bottom end tolerance engines. Not made to last, but to run strong. You're always looking for a few extra HP, so always trying things. They'd give us either Valvoline or Pennzoil for free if we'd put the sticker on the car. Show up at the track and get a few free cases of oil. Why spend 4 bucks a quart for synthetic? Looking for HP, that's why. So we did an A/B comparison. Two new engines, same machine shop, same tolerances, same bearing maker, basically the same engine cloned twice over. One with Valvoline 50 wt, the other with Amsoil 20-40. Same race, same day, same ambient temps. The engine with the synthetic ran cooler in terms of water temp and oil temp. We guessed less friction in the synthetic oil engine was making less heat, and maybe more power. Pressure was down to about 50 psi synthetic vs 60 to 70 psi on the Valvoline engine when hot(same oil pump, same adjustment, same brand gauges). So I decided to pull both pans to see what the wear looked like. The engine on synthetic had bearings that looked just like they did when they were put in. The petro oil engine already had silver streaks in the nice gray bearing babbitt. It had worn more despite more oil pressure. Cranking compression check was still around 350 psi for both engines --no difference -- apparently no ring break in problem. Leakdown test said the same thing. My conclusion was the synthetic made less friction, and less wear. Only downside was that it costs more than the petro oil -- even if you're paying for it.
That's why I've used synthetics since then. I used the free Valvoline in street cars and trucks -- engines I figured I'd have for 3-5 years. For the good engines, the prized engines, something like an expensive race engine or your '51B or my '54 60 I'd use the most expensive oil because I've seen that it will take better care of them.
Steve
Rod
07-22-2002 17:16:05
 Re: Re: Synthetic Oil in reply to Steve - IN, 07-21-2002 23:32:55
If synthetic oils are so good for engine break in why does Amsoil not recommend it. Mobil won't recommend it but will tell you to follow the manufacturers recommendation. Seems like they're not real sure about there products for break in.
Steve - IN
07-23-2002 01:46:02
 Re: Re: Re: Synthetic Oil in reply to Rod, 07-22-2002 17:16:05
Rod,
I cannot find any statement about break in on the Amsoil site. If you have, maybe you could provide a link.
I can find the exact opposite statement on the Mobil 1 site, copied and pasted below:
(myth) You should break in your engine with conventional oil, then switch to Mobil 1. (reality) You can start using Mobil 1 with SuperSyn� in new vehicles at any time, even in brand-new vehicles. In fact, Mobil 1 with SuperSyn� is original equipment (it is installed at the factory) in:
Chevrolet Corvette All Porsche vehicles Mercedes-Benz AMG vehicles Dodge Viper Ford Mustang Cobra R All Aston Martin cars
One of the myths that persists about Mobil 1 is that new engines require a break-in period with conventional oil. Current engine manufacturing technology does not require this break-in period. As indicated by the decisions of the engineers who design these high-performance cars, Mobil 1 with SuperSyn� can be used in an engine from the day you drive the car off the showroom floor. ===== ===== ===== =====
The link below will take you to the statement above on the Mobil 1 site.
G-MAN
07-23-2002 13:38:47
 Re: Re: Re: Re: Synthetic Oil in reply to Steve - IN, 07-23-2002 01:46:02
All I can say, Steve, is that you have a lot of nerve to back up your statements with facts. What are you trying to do? Turn this board into a good source of genuinely accurate and helpful information on all subjects? :)
Steve - IN
07-23-2002 14:12:55
 Re: Re: Re: Re: Re: Synthetic Oil in reply to G-MAN, 07-23-2002 13:38:47
Gman,
Sorry about that. I'll clean up my act.
Steve
Rod
07-23-2002 13:55:11
Well there's facts then there's facts. I still don't see anything about Mobiles policy for synthetic oil used for break in for rebuilt engines. All that hype is for new cars with extremely well machined internal engine parts. He posted no facts for Amsoil at all so I guess the fact is neither of you know for sure. Until you show me a tractor engine that has gone 5000 hours on synthetic I will believe what Amsoil and Mobil told me when I called last year and was told not to use it in a rebuilt engine until after break in. It didn't matter in the end anyhow my engine builder said he wouldn't guarantee the engine if I used synthetic oil.
Doug in OR
07-23-2002 18:48:52
 Re: Re: Re: Re: Re: Re: Synthetic Oil in reply to Rod, 07-23-2002 13:55:11
I spoke with AMSOIL's tech support before I switched my vehicles to synthetic. The rep flat-out told me that using synthetic during break in will do absolutely no harm, nor will it prolong the break-in period. He did say that they prefer to not have users using any oils other than what the manufacturer poured in for reasons of warranty. Reasons on warranty, he went on the say, were because of if in fact, there were manufacture's defects, they would most likely show up early in the vehicle's life.
When it comes to resolving this warranty issue, AMSOIL feels the customer could get a faster resolution if the were no side issues to investigate. He essentially said, "it is just easier, when there is a problem, if you use the OEM oil until the first oil change".
AMSOIL's web page www.amsoil.com makes no statements that I could find, one way or another, on using synthetics during break-in.
Steve - IN
07-23-2002 14:31:32
Rod,
I'm inferring from what you say that if a rebuild doesn't have well machined parts, you just shouldn't use a synthetic. I've never called them, just posted what I found in print.
I didn't find anything about break in on the Amsoil site. Least that's what I thought I said.
I asked if you did. I didn't see your answer.
I'm not trying to sell you the stuff, Rod. I use it, and have used it on fresh rebuilds. If you don't, and don't want to, that's your choice. This freedom of choice stuff is one of the things that makes us proud to be Americans, isn't it? Best of luck is getting 5,000 trouble free hours from your rebuilt engine.
Steve
Rod
07-23-2002 14:53:31
 Re: Re: Re: Re: Re: Re: Re: Synthetic Oil in reply to Steve - IN, 07-23-2002 14:31:32
My answer was I called Amsoil about a year ago and their oil rep said not to use for break in.
I wanted to use synthetic but was told not to use for break in. My engine rebuilder said not use it period. I hope to get over 5000 hours on this rebuild the last one this guy did for me went well over 5000 with only rings and a valve job.
G-MAN
07-23-2002 16:39:39
 Re: Re: Re: Re: Re: Re: Re: Re: Synthetic Oil in reply to Rod, 07-23-2002 14:53:31
What brand and model engine are you talking about here? You say that your engine went well over 5000 hours with only rings and a valve job. I assume that since you didn't say over 6000 hours that you had it rebuilt somewhere in between. I hate to tell you this, but that's not that impressive - especially for a heavy-duty diesel or even a quality gas-burner. It's not uncommon to see Deere engines go up to 10,000 hours without overhauls with proper maintenance, and 7500 with even questionable maintenance. My grandpa owns a IH 1086 that had 13,000 on it without the head being removed once. We have a 4955 in the shop now with over 7000 hours on it. It was to have the rods and mains replaced, but the crank was scratched some, so it was pulled and polished with the rest of the engine left assembled. I would probably have overhauled the whole thing, but I ain't writing the check. It's now fairly common for over-the-road trucks to go 1,000,000 miles between overhauls. Divide that by 50 mph average speed (which is probably unlikely, given the idle time) and you have 20,000 hours. I also question your reference to "finely machined engine parts". If you're at all familiar with diesels, you'll know that many injection pumps are lubricated by engine oil. The actual pumping elements are lubricated by fuel, but the governor, pump cam and followers, etc are lubricated by engine oil. You'd be hard pressed to find parts more finely machined than those in an injection pump - some clearances are measured in millionths of an inch. I tend to think that synthetics are superior, the issue of break-in notwithstanding. I doubt if Corvette engines are any more "finely machined" than any of Chevy's other engines, such as the Duramax Diesel, 8100, 6600 etc. More probably, it's just a prestige thing that they tell Vette owners to use the synthetics, to make them think they're driving something real special. And I also doubt that GM breaks in the engine with some mystery oil and then drains it and refills it with Mobil, so the synthetics being bad for break-in idea doesn't fly too well with me. I guess it doesn't matter what oil you use, as long as I'm paying for it, I'll use whatever I like and everybody else will do the same.
G Taylor
07-23-2002 19:34:33
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Synthetic Oil in reply to G-MAN, 07-23-2002 16:39:39
Synthetic is fine for new or rebuilt engines which are bored with torque plates,properly honed and using compatable rings. Such as the case with new LT1,LS1 and LS6 engines. Synthetic was required in those cars to reduce heat production and handle the still elevated temps. My Grand National wasn't built that well and had Mobil 1 installed right after she came home.Took 30,000+ miles to seat the rings and quit burning oil. It now has 290,000 miles on the origional bottom end. Guess it wasn't hurt too much by synthetic oil.
Steve - IN
07-23-2002 22:18:51
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Synthetic Oil in reply to G Taylor, 07-23-2002 19:34:33
To each his own.
G Taylor. In addition to using the torque plates, a good Sunnen hone, and the right stones, it also helps to run 200 degree water thru the block while it's being honed. The torque plates simulate the torsional stress of the head and crank, while the water simulates the thermal stress that deforms the block in actual running conditions. You get better sealing in the combustion chamber when you do that -- theory is that the cylinders are more true, and the rings just seat better because of it. Just something to think about. If you like the idea, I'll tell you about dykes rings sometime.
I expect someone to say I'm wrong about the above. Just like synthetics. Interesting things, opinions. One nice thing about racing is that you knew what worked when the green flag dropped and the talk (to use a polite term) stopped. Actually, there generally was no talk. If I found or learned of a trick like hot water honing and synthetics worked on the dyno and on the track, I surely wouldn't talk about it... much less try to persuade a competitor to use it.
I don't view guys here as competitors. If I spout off about something that's worked for me, and even give some substantiation for it -- you're still free to take it or leave it. No hard feelings. Just don't question my ancestry. Life is far too short to argue over free advice.
Glad your car is doing well, G Taylor. A Grand National has a straight rear end, I think. You ought to try a synthetic there. Call me crazy, but my notes say it drops the operating temperature. I take heat as a symptom of friction, and anything that reduces heat as a good lubricant. Don't use synthetics in a sync gearbox, but it's good in straight ones.
Steve
Dr. Evil
07-24-2002 08:09:56
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Synthetic Oil in reply to Steve - IN, 07-23-2002 22:18:51
Book says I'm supposed to use sythetic ATF in the manual transmission in My Ford Pickup. AMSOIL sure makes it shift nice! Same transmission the new Chevys use too. And syn. ATF in the transfer case.
Doug in OR
07-24-2002 16:38:29
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Synthetic Oil in reply to Dr. Evil, 07-24-2002 08:09:56
My Nissan pickup has a sync gearbox, and for about 6 months after switching that to synthetic gear oil, I had to shift very slowly into third gear - until after about a mile of driving. Otherwise, I'd get a little bit of gear grind. Looks like the manual transmission issue varies, depending on make of vehicle. Steve may have something there.
My car will be changed to synthetic ATF at the 30,000 mile automatic service. I'm planning on using AMSOIL - they say to expect 100,000 miles between changes there. To me, it is worth the extra initial expense.
And for that anti-synthetic crowd - and I agree with Steve in an earlier post - do what you like with your equipment, just don't trash me personally - Mercon is synthetic. And from what I understand, the new GM spec DEXTRON will be synthetic.
Steve - IN
07-25-2002 06:48:06
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Synthetic Oil in reply to Doug in OR, 07-24-2002 16:38:29
Doug,
You hit the nail on the head with the manual gearbox. I should have been more detailed, but the thought is that the syncro rings like a bit more friction to operate properly, and the synthetics are too slippery. Damn synthetics! Ha!
take care,
Steve
G-MAN
07-22-2002 07:44:37
Good post and good information, Steve - especially on the head to head test. I've often wondered about guys that spend thousands of dollars restoring their old tractors and then just put whatever oil they happen to have laying around in them. The theory that it's old technology and able to use anykind of lubricant only goes so far. The new, high quality lubricants available today go hand in hand with the new metallurgical and machining processes available today to create the extremely reliable engines that are produced. I would think that if the engine were properly rebuilt and all the clearances were proper, a two-cylinder would be able to take just as much advantage from the newer synthetic oils and a newer engine. I know guys that restore old cars and many of them use synthetic oil - just because of the fact that it allows for less wear on expensive and hard to find internal parts. I plan on breaking in my G with extended dyno sessions on JD break-in oil, and then switch over to a good synthetic. I've built a couple high-performance V-8s and never put the kind of money in those that I will have in this old two banger, so I want it to last.
smotch
07-21-2002 20:57:30
Barry, as Clooney stated break the engine in for sure if you do intend to use synthetic oil. I have used John Deere break-in oil and it seems to work well. I run synthetic in my diesel pickups in the winter in Mn. and have not had the block heater plugged in for the past 5 yrs . I have several freinds that do the same and feel it is worth the extra money .
Clooney
07-21-2002 17:52:44
Barry, you really shouldn't break an engine in using synthetic oil of any kind. Those synthetic oils are pretty slick & tend to keep the rings from seating properly.
~While synthetic oils probably won't hurt the engine after break in they are designed for newer automotive applications that have tight controlled bearing & piston fits & that use modern tight sealing seals on new highly machined shafts. One of the advantages of the synthetic oil is it's ability to creep into tight places & that oil will migrate into places mineral oils won't. The old Deere 2-cylinder engines are hard enough to keep mineral oil from leaking out of & would be much harder to keep the synthetics in. The Deere 2-cylinder engines don't even use seals in some places so the chance of leaving oil spots under the tractor would be higher.
~In my estimation about all you gain with synthetics is a little better flow in extremely cold ambient temperatures & the ability to run the oil at higher sustained temperatures without oil degradation [the oil in the old 2-cylinders doesn't run that hot so that part doesn't mean much]. The cold flowability might mean something if you regularly start your tractor in below 0* weather. Keep in mind that most modern mineral based motor oil contains some synthetic additives.
~In my own personal tractors I use straight weight [usually 30 or 40 depending on the age & tightness] & use multi weights in my year round use tractors, or 30 weight in the summer & 10W30 in the winter. In a couple of the newer diesels I use 15w40 diesel rated oil..... .
Tractorboy
07-21-2002 17:10:29
Well we have been here before but I have never commented on this subject so here goes my 2 cents worth. If you have done everything to proper specs and have thoroughly cleaned and boiled the complete engine and every seal and hole is up to specs I feel the new synthetic oil is the way to go otherwise you had better stick to the other oils. The new oil today is a much better quality than what it was 40 years ago.
