Jd 70 tire size
GM
07-20-2002 02:03:14
Heyas,
Just wondering if anyone is around
to give me the rear tire sizes that will fit
a standard jd 70 gas tractor. There is an auction this afternoon with some 20.8x38's. My jd 70 is over at the farm,
so i cant check it
-Greg
G Taylor
07-21-2002 15:01:39
 Re: jd 70 tire size in reply to GM, 07-20-2002 02:03:14
The standard chassis tractor and a rowcrop with a wide front are often confused. The standard 70 had 14-30/16.9x30,15-30/18.4x30 or for rice/western usage 18-26/23.1x26. Rowcrops were equiped with 12-38/13.6x38 or 13-38/14.9x38. 20.8" would be pinched pretty narrow on 12" or 13" wide rims unless they were swapped for 18".
Jack
07-20-2002 13:44:24
My 70 gas rowcrop had 14.9 38's on it originally and looked and performed well with them.I don't know if you are talking about a rowcrop or standard.
gm
07-20-2002 23:39:18
 Re: Re: jd 70 tire size in reply to Jack, 07-20-2002 13:44:24
They turned out to be quite a bit wider,
mine are probably the 13.9. I guess
if I could have gotten them on my tractor
it would have been great though. I didnt
stay to see what they went for.
Everything was going crazy high.
The hay wagons went for $2k to $3k,
as did the baler, haybine... The wagons
looked good but seems like they were getting
close to new prices. The best deal was probably a case 730 for $2800 but it did have a few problems so maybe it was the right price.
-Greg
Dan
07-20-2002 06:39:25
Hey Greg, my 70 standard takes 18.4 - 30. on the rear,same as on the JD 2550.
