JD 60-rocker arm end play.?
Lenn
07-19-2002 17:57:41
The tappets seem a little noisy,i checked the gap and they are set at 20 hot.
The outer rocker arms seem to have a lot of end play in them,i see they only have a single washer between them and cotter key. The inner rockers have springs between them,are you supposed to add shims to the outer rockers to eliminate the end play or are they supposed to be that way.I was wondering if thats where the noise is coming from,or are they normally a little noisy?
Thanks.
smotch
07-19-2002 23:08:36
 Re: JD 60-rocker arm end play.? in reply to Lenn, 07-19-2002 17:57:41
Lenn Have you checked to see if the rocker arms are wore where they contact the valve stem? I have seen where a person gets a false clearance setting because of this. If you back the setting off as far as you can you should be able to visually see if there is wear. You can get the rockers refaced at any good machine shop.When they are done properly there is a nice even contour where the rocker and the valve meet . I hope this helps as for the end play I don't think thats the problem.
Lenn
07-20-2002 05:11:41
 Re: Re: JD 60-rocker arm end play.? in reply to smotch, 07-19-2002 23:08:36
Thanks smotch,i didn`t ck. that but i will,i have the cover back on now because i needed to use the tractor.
I mainly wanted to know if the end play is normal,which you answered also.
Thanks again.
Lenn
