Baler Help!!!! Please it's going to Rain...
Jeff
07-18-2002 19:51:36
Hi, i've borrowed a friends JD 14T baler. i'm having trouble, while i'm baleing the grass hay starts to wrap around the feeder auger??? am I going to fast,to slow,or not enough in my windrow?? also trying to adjust tension bales are short and a little loose? last ? from the back the twine on the right has broke three times and have to re-thread am I doing something wrong? Thank You Jeff From WI Farm Country.
Jeff
07-20-2002 06:55:49
 Re: Baler Help!!!! Please it's going to Rain... in reply to Jeff, 07-18-2002 19:51:36
Thank You To All, For All Your Help!!!!! I got Her All Baled. Thanks Again Guys.
Chuck
07-20-2002 03:43:43
Jeff the friend you borrowed it from should be able to answer better than anyone here, he has used it and knows its tricks.
Dan
07-19-2002 12:44:43
Generally these balers have the opposite problem with the auger, just slip across the hay. Teh washer trick below might help, have also seen them with small cuts, maybe 1/8 deep on auger done with hacksaw. Tension should be by tightening screws on the back that you tighten to get more tension and heavier bales. Twine can break for lots of reasons, one thing to check is that there are no rough spots on the areas it is pulled over, ends of needles, guides etc. Make sure it is threaded right also. If tension is too tight it may not pull through quick enough when it ties. Other thing I found on a baler once was a bolt that was too long on the bottom of the bale case, twine would catch on it and break. If you get too much hay on the right side of the bale that will cause it also, from feeding off center or uneven windrows or adjustemnt to feeder forks. some possibilities anyway
Tom P
07-19-2002 11:11:05
Don't complain, at least you're getting some rain!
thurlow
07-19-2002 07:39:24
I would suggest that your hay is what we locally call "in case"; i.e. too much moisture. It may be totally cured, but if the air is too heavy, the hay can pick up enough moisture that it will not feed properly. Never had that problem with square baler, but have wrapped various shafts/rollers many times with large round bales.
Mr. Tracthrob
07-19-2002 00:55:44
Maybe the grass hay is too green and grass-like.
Andy H
07-19-2002 06:11:18
 Re: Re: Baler Help!!!! Please it's going to Rain... in reply to Mr. Tracthrob, 07-19-2002 00:55:44
Your hay may be to green, on our old IH, and JD bailor's we put some 5/8" lock washers, on the auger, it sure did help feed the hay in better, just put the split of the washer, onthe edge of the auger, and take a hammer and tap it down all the way, 6 or 12 what ever you have, any size around the 5/8 size.
