JD R 1949 Oil question
Al
07-18-2002 18:30:14
Have 1949 JD R. Drained oil today it was thin and found diesel in oil how could this happen? Also when we drained we found 5/16 inch standard thread nut where could this have come from in the engine?
Any help would be appreciated greatly.
Al
Clooney
07-18-2002 18:55:51
 Re: JD R 1949 Oil question in reply to Al, 07-18-2002 18:30:14
Al, pull the rocker cover & square pump cover [on top of the block] & look for a loose injector line fitting or cracked line. Look for clean spots that may have diesel fuel sprayed on them.
~If nothing found there you might want to run the engine with the covers off to look for a fuel leak [caution: do not use your hand to check for leaks with the engine running as that system has enough pressure to blow oil under you skin & that is dangerous].
~If nothing found with internal lines or fittings suspect the fuel transfer pump seal...
~I don't know what to tell you on that nut, it could even have been it the funnel or oil container when oil was added..... .
Gpower
07-18-2002 18:35:56
Well as bad as I hate to say this, there are a few ways that diesel can get into the oil. One is you could have worn cylinders, or broken rings, this will show up however by letting it idle about 30 minutes, and then you hammer down on it and you look like youi have been plague with black spots as bad as the chicken pox. Aother thing is it could be the fact that you have an injector that is not spraying correctly and it is dribbling into the sylinder and not burning correctly. Usually that is the cheapest and first thing to check. Anyhow, just some ideas. Good luck
Gpower
