Check Oil in 1937 Model D
Stevie
07-18-2002 14:43:48
Hello. My friend has a 1937 D and we didn't find a way to check the oil. HELP!! Thanks
Clooney
07-18-2002 17:50:44
 Re: Check Oil in 1937 Model D in reply to Stevie, 07-18-2002 14:43:48
Stevie, there is an oil test cock on the pulley side of the engine way down on the side of the crankcase. [it's just about even with the pulley "actually just a little behind the pulley center" & about the same height as the lowest point on the 1st reduction cover]
~To check the oil, open the test cock [it takes a 3/4" end wrench] & if it is full, oil will drip out, if it doesn't, just leave it open & add oil until it drips out then close the test cock & enjoy....NOTE: tractor should be level before testing....
