41 B Clutch
KrisA
07-18-2002 08:43:12
My '41 is a hand crank. When I throw the fly wheel over the clutch pully spins also. It is out of gear, the wheels don't move and as far as I can tell the clutch is disengaged. Am I looking at a clutch rebuild here? Have got a '39 B when thrown over the clutch doesn't move. Any help is always appreciated.
Kris
Clooney
07-18-2002 08:59:37
 Re: 41 B Clutch in reply to KrisA, 07-18-2002 08:43:12
Kris, that�s normal if the pulley brake isn't adjusted tight enough to hold it from spinning with the clutch disengaged.
~It sounds like the pulley brake might be just a little tight on the '39, or the linkage is so loose that the lever weight is pulling on the brake.
KrisA
07-20-2002 15:10:37
 Re: Re: 41 B Clutch in reply to Clooney, 07-18-2002 08:59:37
Clooney, thanks for the reply, I will give a look to both of them. I didn't think it was a problem, but I wanted to make sure!
