Flat Head for a late G
Frank
07-17-2002 18:51:23
I am looking for a Flat Head for a late "G", would prefer in SW Mi. Thanks in Advance
DPOST
07-18-2002 06:50:39
 Re: Flat Head for a late G in reply to Frank, 07-17-2002 18:51:23
Frank;
My turn for a dumb question. I keep seing posts about flat heads, what is a flat head for a G?
I suspect it is simular to a regular head but with smaller cavities for the combustion chamber to rase compression.
Can you tell a flat head form a regular head form the outside of the engine?
Were the flat heads an option form JD? or were the an add on?
Thanks in advance for your answeres
D.D.Post
G-MAN
07-18-2002 07:32:32
 Re: Re: Flat Head for a late G in reply to DPOST, 07-18-2002 06:50:39
The "flat" heads were used on the unstyled tractors. I believe the unstyled tractors had a block that was 1 inch longer than the styled tractors, and they needed a smaller combustion chamber volume to keep the compression ratio the same. A simply trick to raise compression on a styled tractors is to remove the stock head and install a flat head.
