Carburetor
H
Minnesota
07-17-2002 17:25:19
I wonder if I can get some help from you good guys! For some reason the butterfly in the carburetor on my H had been welded shut. I got a new butterfly, now I can't get the same answer from different people how the butterfly goes - does the little flap go towards the engine or towards the air cleaner? Also, when it is open, is the little flap on bottom or on top of the shaft. Thanks so much.
Clooney
07-17-2002 17:34:09
 Re: Carburetor - H in reply to Minnesota, 07-17-2002 17:25:19
Minnesota, the little spring loaded trap door goes in so it opens into the carburetor [with the choke closed] & the trap door goes towards the bottom with a closed choke. [below the shaft with a closed choke, on top with the choke open]
