Backfiring B
Green_in_MI
07-16-2002 20:17:31
My 49 B was never easy to start but now all I get is an occasional backfire when cranking. I have put in new condensor, points, wires, and plugs. The plugs now get a good spark when cranking. Still it just does the occasional backfire. When it did run last year it sounded more like a sewing machine than a tractor but it did run well enough for light work around the yard and had a fair amount of power.
There's more. Last winter I did not drain the antifreeze as in past years. In the spring I found antifreeze in the cylinder. I was hoping that it was a leak through the push rod tube instead of a cracked head. It did not get very cold at all in mid-Michigan last winter. Thinking sticky valves I opened the valve cover and heavily sprayed PB blaster. Everything looked great as i cranked it over and watched the valve spring action. I also drained the old gas and put in new. I am leaving the water out until I get it started. Still just an occasional backfire.
Are my valves sticking? Cracked head and lousy seals? Jumped timing? I plan on rebuilding a lot of this tractor but it has to wait its turn due to another tractor project in the "shop". The "shop" being where my wife would normally park her car. Any suggestions for getting this B running?
Larry W.
07-17-2002 04:45:48
 Re: Backfiring B in reply to Green_in_MI, 07-16-2002 20:17:31
Sounds like the plug wires are crossed. As for the antifreeze in the engine, options are many, but pushrod tubes are always the first guess.
Clooney
07-17-2002 03:23:19
Green, does it feel like it has compression when cranking? [if not add a little oil through the spark plug holes & try it]
~You say it has spark? How much & what color. [take an old spark plug & open the gap to 3/16"-1/4" & see if your spark will jump that, & if so is it blue & not yellow? [if it won't jump that gap with a blue spark, tell us what brand & type of mag or distributor you have]
~ Sometimes after it pops a few times you might have to remove the spark plugs & clean them with starting either or break clean [if there is old fuel or an oily residue in the cylinders it can end up on the plugs after a half hearted pop or two & if that happens no amount of cranking will start it.
~If all ok per above, remove both spark plugs & lay them on the block or frame & turn the flywheel slowly in the starting direction. As the L/H cylinder starts to make compression watch the L/H plug as the "L/H impulse" mark on the flywheel lines up with the case mark [at 3 o'clock behind flywheel], the L/H plug should spark when the L/H impulse lines up with the case mark [or close to it].
~If the spark is good & at the correct time, make sure you are getting good fuel flow THROUGH the carb [open the carb drain & make sure you have a good steady stream of fuel form it for at least 30 seconds]
~I all is ok per above you might try pull starting it with another tractor or your truck..... ..
Green_in_MI
07-18-2002 17:55:57
 Re: Re: Backfiring B in reply to Clooney, 07-17-2002 03:23:19
Thank you for the advice Clooney. I have a Wico C mag on this tractor. I did all your suggested tests with acceptable results except I only got a tiny dribble of gas through the petcock on the bottom of the carb. Does this mean a carb rebuild is in order?
Clooney
07-18-2002 18:24:14
 Re: Re: Re: Backfiring B in reply to Green_in_MI, 07-18-2002 17:55:57
Green_in_MI, you need to find out if the fuel isn't getting to the carb or is getting to it & not through it.
~Remove the fuel line at the carb & see if you are getting a good flow from that line [is not suspect the fuel strainer or fuel shut-off valve or even the fitting going into the tank], if you are getting good flow there & not out the bottom of the carb suspect needle & seat, carb screen, stuck float or ? in the carb.
