Rockshaft
Andy
07-16-2002 14:53:08
I am working on a 45 slant dash A, redoing motor, and the fellow want's the lift to work, they won't go up or down, used a big wrench it's tight. I pulled the plugs out of the back, moved the leaver still won't move, put the plugs in and tried it still won't work, is their any way to check it? thanks Andy
Jerry S
07-17-2002 07:47:54
 Re: rockshaft in reply to Andy, 07-16-2002 14:53:08
I would take the valve body off the rockshaft housing (7 bolts I believe) then you can get in there and see what the piston is like in the cylinder straight toward the front of the tractor. That might save breaking something and let you know if you need to take the whole lift assembly off the back of the rear axle.
