John Deere 60 Automatic Fuel Shut off Help
Dan Wilkey
07-16-2002 08:37:09
I have recently bought a '54 60. I was told to rebuild the low oil pressure fuel shut off on the sediment bowl because it doesn't shut off the fuel. The screw on top is loose and has no force against it from the bottom. I took it apart and haven't quite figured out how it works. I was told there should be a spring in there, but I haven't found one. If someone could e-mail me a diagram of the shut off and mabey some tips, it would be much appreciated. Thanks
Clooney
07-16-2002 12:28:03
 Re: John Deere 60 Automatic Fuel Shut off Help in reply to Dan Wilkey, 07-16-2002 08:37:09
Dan, that screw on the top of the strainer does float loose when the knurled knob is loosened. All it does is push down on the actual valve inside the strainer to open the valve when pushed by hand. [used before oil pressure is built to allow gas to go to the carb].
~I sent you a picture by E-Mail..... .
Dan Wilkey
07-17-2002 06:12:12
 Re: Re: John Deere 60 Automatic Fuel Shut off Help in reply to Clooney, 07-16-2002 12:28:03
Thanks for the great picture and explaination.
