40 fan bearings
Bill
07-16-2002 04:12:18
Is it possible to lubricate the fan bearings on a 40? The service manual says non-servicable, the parts manual gives a breakout of all the individual parts but only lists a # for the complete assembly, at $340.
JDM Guy
07-16-2002 05:13:29
 Re: 40 fan bearings in reply to Bill, 07-16-2002 04:12:18
Well the M which is the little brother to the 40 has a screw you can take out and oil inside. Your 40 may have this screw or if it doesn't you will have to take it off and pack it with grease.
Brad
07-16-2002 11:28:50
 Re: Re: 40 fan bearings in reply to JDM Guy, 07-16-2002 05:13:29
m guy you sure like to say something even if its wrong. the m isnt a little brother to the 40 its the predecessor to the 40. seeing that bering on the 40 is a sealed bering why dont you tell us how to take it off and pack it with grease? i would love to here how you do that/
Wayne in Tn.
07-16-2002 12:11:10
 Re: Re: Re: 40 fan bearings in reply to Brad, 07-16-2002 11:28:50
Bill, Brad is correct, according to the manual, the fan assembly "40" series tractor is mounted on special ball bearings which are packed and sealed at the factory. It will not be necessary to lubricate these bearings. No attempt should be made to disassemble it. Replace the unit if bad.
