420 starting problem...
Karl Bader
07-15-2002 15:23:21
I am having some trouble with my 420. I went to start it the other day and nothing happened, so I took the battery in and the charger said it was had no charge, so I put it on the charger. It charged up, today I put the battery in and went to start up, still nothing. I turned on the lights when I tried to start it, the lights came on until I pulled the starter, then the lights went completely out and didn't come back on until I hit the pos terminal on the tractor a couple of times and the lights came on, this continued to happen, so I took the battery off and it needs a serious charge again. I am wondering if it is the battery that is having trouble and just needs replacement or something is shorted out and needs fixing. I was wondering what I should do. Any help would be apreciated. This tractor is still 6v pos ground. It is a 1956 420T.
Thanks,
Karl
Clooney
07-15-2002 15:32:18
 Re: 420 starting problem... in reply to Karl Bader, 07-15-2002 15:23:21
Karl, it sure sounds like a bad battery, or a loose or poor battery cable connection. See if you can find someone to do a battery load test & if it fails replace it.
~Make sure both battery cables are clean & tight & the ends are not loose or the wire corroded where it enters the ends.....
