JD 820 Center Main Bearing Spun, Repair Solution?
Kevin
07-15-2002 06:56:45
I'm working on a JD 820 2 cylinder and the center main bearing is spun. It is a pulling tractor and it needs a proper fix. Since the center main quill is two piece and part of the crankase/ transmission case, replacement of this casting is not an easy option. Normally, line boring is a fix but with the outside mains each as one piece this is not possible either. Has anyone repaired such a problem?
G Taylor
07-16-2002 08:55:41
 Re: JD 820 Center Main Bearing Spun, Repair Solution? in reply to Kevin , 07-15-2002 06:56:45
Albert has two cylinder diesel bearing problems solved.
[email protected]
Business Information: Phone: Ph.# 360-748-0026
