JD 40
which one?
JD
07-14-2002 18:31:56
I looked at a 40 for sale. Its a "T" with a wide front. Is this the 40 "w" or just a 40 T with a factory wide front? the SN is 64982 and there is a number on the trans housing M1782T. I know there were about 17,000 40 T's made but how many were wide front?
Thanks for the help
Wayne in Tn.
07-15-2002 13:56:10
 Re: JD 40 - which one? in reply to JD, 07-14-2002 18:31:56
Jd, if it is a 40w it should say so on the serial tag ie; 40W-64982 If it has just 40-64982 then it is a T with a wide front. The T tractors could be ordered in any configuration, wide, tricycle, or single front wheel. Also there were several different wide fronts avaialble. Also if it is a W it will have different final drives than the T the brakes will be internal on a W and external on a T.
