Clooney ....M question
51M
07-13-2002 17:12:08
My 51 M runs great but when i put it into 4th gear and pull out the clutch the engine starts popping on one cylinder and after going about 20 feet it slowly begins to go back to 2 cylinders. Does this make any sense. Not to me. Throttle is at full and it still does it. thanks so much for your time
Clooney
07-13-2002 18:05:34
 Re: Clooney ....M question in reply to 51M, 07-13-2002 17:12:08
51M, it sounds like it is either running a little too lean [try richening the load screw about 1/4-1/2 turn].
~Or you are losing spark due to higher combustion chamber pressures under load. [it takes more KV to fire a plug under load than just running under no load & if the plugs are marginal for fouling the spark will just travel down the center electrode & won't jump the gap]
~Start with a new set of spark plugs & if that doesn't help, richen the load needle 1/2 turn, if that doesn't help open the point gap slightly, if that doesn't help try new solid core ignition wires.
~After you try the above, if it still acts up post back, but I'm thinking the new plugs or richening the load needle will help it.
~As a quick check, try launching it in 4th gear with the choke 1/4-1/2 on & see if that helps, if so a load needle adjustment will probably help....
