My newly-acquired 720LP came with electronic ignition and I'm having problems starting the tractor. When I pull start it, she fires right up, but when I crank her over with the starter, it's very hard to get her running. (Battery was charged overnight so I know there's enough juice.) The coil (installed new with the ignition) gets real hot while I'm cranking the engine and never cools off even after running the tractor for a couple hours.I took my VOM to the coil and here's what I found: switch "on", engine not running: 12+volts switch "on", starter engaged: 1-2 volts switch "on", tractor running: 2.2 volts Plugs are clean and gapped to about .025". I haven't traced the starting circuit yet, but was wondering if the voltages I'm seeing across the coil is typical of the electronic ignition system. I need to see if it's wired to feed 12 volts to the coil during cranking and that the ignition switch is working correctly. Should the starter on the 720 have that extra 12-volt terminal for direct feed to the coil when cranking? Your responses are much appreciated!
