Ever Used Mystery Oil?
JDM Guy
07-11-2002 03:26:56
Just went down to Wal-Mart to buy some mystery oil. I heard it helps your rings and valves. Any of you guys use mystery oil in your JD's? Is there any defects? Thanks
DON
07-11-2002 15:48:41
 Re: Ever Used Mystery Oil? in reply to JDM Guy, 07-11-2002 03:26:56
It is pretty good oil, however I use it to lube my air tools.Don
Clooney
07-11-2002 06:39:22
JDM Guy, while it does give some upper end & valve lube & has been used for years by many people as a gas additive, it doesn't burn that clean & tends to settle out if stored for long periods causing fouled plugs when the tractor is removed from storage.
In the past I have used it myself in tractors that weren't used often.
~I have found that a good quality 2-cycle oil will lube just as good if not better & burn much cleaner under combustion..... .
JDM Guy
07-11-2002 06:31:43
Sounds good, I'll try it. Thanks
ChuckW
07-11-2002 04:56:05
I use it all the time. This is a real old product and reminds me of sewing machine oil. Is a penetrant and works great to free hydraulic valves. Personally I don't think it will do anything for old tractors and I doubt there is any product that would loosen rings in one of these and I'm not sure you want them loosened unless you are removing them. Anyway this is a great product and you may want to check it out.
al
07-11-2002 05:29:45
 Re: Re: Ever Used Mystery Oil? in reply to ChuckW, 07-11-2002 04:56:05
I use it as a gas additive in all my lawn equipment and JD tractors. I know for sure it helps with lubricating the valves as I had a valve that would stick when hot, after using Marvel Mystery Oil it never stuck again. I think it helps on the old JD's but I've never put in the crankcase.
JD60
07-11-2002 10:06:54
 Re: Re: Re: Ever Used Mystery Oil? in reply to al, 07-11-2002 05:29:45
I'm with you Al,
I used it on a I/O boat engine that had a top chadder, I believe it broke down the carbon build up around the valves. Anyway, after a bit the thing choked and caughed and the chadder went away and thing ran a lot better/with more power.
I put it in my car/truck, van, lawn eq. and tractor as an additive to the gas.
