Will 47A engine rock shaft fit a 36A
Ben.So.Tex
07-10-2002 19:41:22
I am going back together with my 36 A, I notice that the valve have worn a good size grove in the tappet.I have a chance to get the rock shaft off a 47A.Will it work??? If it wont fit can I weld up the groves??? or should I try to grind them smooth??? I would like to hear it come back to life, after a 25+ years of sleep.Thank Ben
cole in mo.
07-11-2002 00:11:35
 Re: Will 47A engine rock shaft fit a 36A in reply to Ben.So.Tex, 07-10-2002 19:41:22
Ben, if memory serves me right the 46 A has forced oil feed to the rockers, where the 36 has a drip feed system. maby sombody with a better memory can shed some more light on this.
Craig
07-10-2002 22:02:23
Some automotive machine shops or tractor repair shops have an attachment for their valve grinding machine that is used to reface worn rocker arm ends. I'd check that out.
